Activation code does not work
lpcware
Content originally posted in LPCWare by edd on Wed Aug 31 05:40:58 MST 2011
[SIZE=2]I performed the Activating your product procedure however the license type still shows unregistered. I have tried a few times with the same results and have uninstalled and reinstalled the software again with the same results. The serial number and activation code are below and I have attached the .loc and .acc files.[/SIZE]
[SIZE=2][/SIZE]
[SIZE=2]Thanks,[/SIZE]
[SIZE=2]Ed[/SIZE]
[SIZE=2][/SIZE]
[SIZE=2][SIZE=3]Thank you for registering your product with serial number:
[B]GQP5-L4L3-J0LX-JWPZ-IVDU-MROU-O4HQ-ERMR-MVCQ-BWKX[/B].
Your activation code is:
[B]J1EX-L2L3-GVP4-AVE4-N2MU-E0GX-LVB4-K5F3[/B][/SIZE]
[ATTACH]541[/ATTACH]
[/SIZE]
lpcware
Content originally posted in LPCWare by CodeRedSupport on Wed Aug 31 09:45:01 MST 2011
Did you see this?
http://support.code-red-tech.com/CodeRedWiki/LPCXLicenseDiag
Also try running the 'findhid' script that can be found in <install>/lpcxpresso/bin/scripts and posting the results
