ARM (Refresh variables while firmware runs)
777件の閲覧回数
lpcware
Content originally posted in LPCWare by Nikos on Fri Jan 20 03:05:56 MST 2012
Hi everybody
I am coming from freescale world and I want to switch to ARM controllers.
Does anyone know if ARM micros are able to refresh variable window while the firmware runs? (just like freescale HCS12 micros)
Example:
RUN/GO button is pressed.
Firmware is running.
Variable window refresh variables every 100ms.
If so what JTAG debugger I have to buy?
Thank you
Nikos
2 返答(返信)
770件の閲覧回数
lpcware
Content originally posted in LPCWare by TheFallGuy on Fri Jan 20 04:16:53 MST 2012
The ability to view memory while the processor is running is a feature of Cortex-M processors from ARM. i.e. it is not available in ARM7 or ARM9 parts.
770件の閲覧回数
lpcware
Content originally posted in LPCWare by Ex-Zero on Fri Jan 20 03:19:31 MST 2012
Perhaps: http://www.code-red-tech.com/red-probe-plus.php
with Trace:
http://www.uchiembedded.co.in/Red_Suite_4_Trace_Guide.pdf
