44.1KHz timer0 interrupt rate
733 次查看
lpcware
Content originally posted in LPCWare by timos2302 on Tue Jun 21 15:30:05 MST 2011
hello guys,
I am trying to make the timer0 interrupt to tick at 44.1KHz (LPC1769 XPresso board).
I made the above program and debug it to an oscilloscope (pin0.22-led),
but i get 25KHz.
What setting i am doing wrong ?:confused:
Any ideas?
All files attached below
726 次查看
lpcware
Content originally posted in LPCWare by timos2302 on Thu Jun 23 02:10:03 MST 2011
Solved , my mista ke , i am sorry guys , thanks all for replying , (stupid me :P)
726 次查看
lpcware
Content originally posted in LPCWare by Ex-Zero on Tue Jun 21 15:36:32 MST 2011
You're kidding :confused:
Your timer is running with 25MHz, your
#define TIMER0_INTERVAL       1000      //Timer0 reload compare value (Scope read 25KHz)
is dividing this by 1000, so what do you expect?
