11u24 bricked
11u24 bricked
3,227件の閲覧回数
Content originally posted in LPCWare by mattes on Sun Feb 23 10:37:34 MST 2014
I uploaded some sample code successfully to the my 11u24 dev board.
the sample code works fine but I can't upload any new code no longer.
lpcxpresso ipload errors with 'MEM-AP is not selected'.
How do I unbrick the board?
16 返答(返信)
3,218件の閲覧回数
Content originally posted in LPCWare by embeddedguy on Tue Apr 22 10:40:16 MST 2014
Now I can't post anything?
3,218件の閲覧回数
Content originally posted in LPCWare by embeddedguy on Tue Apr 22 10:38:17 MST 2014
7th is a test of wikipedia again:
http://en.Xikipedia.org/wiki/LPCXpresso#LPCXpresso_boards
3,218件の閲覧回数
Content originally posted in LPCWare by embeddedguy on Tue Apr 22 10:37:24 MST 2014
okay - 6th post:
http://www.nxp.com/products/microcontrollers/cortex_m0_m0/lpc800/#solutions
3,218件の閲覧回数
Content originally posted in LPCWare by embeddedguy on Tue Apr 22 10:36:57 MST 2014
I bet nxp.com post will work:
3,218件の閲覧回数
Content originally posted in LPCWare by embeddedguy on Tue Apr 22 10:35:37 MST 2014
test 2
http://en.wikipedia.orX/wiki/LPCXpresso#LPCXpresso_boards
can't post wikipedia link
3,218件の閲覧回数
Content originally posted in LPCWare by embeddedguy on Tue Apr 22 09:36:40 MST 2014
Youtube test post:
http://www.youtubX.com/watch?v=chFv1EiZcYo
3,218件の閲覧回数
Content originally posted in LPCWare by nxpsupport on Tue Apr 22 09:34:00 MST 2014
Test post:
http://www.youtube.com/watch?v=chFv1EiZcYo
3,218件の閲覧回数
Content originally posted in LPCWare by starblue on Wed Feb 26 05:47:22 MST 2014
Quote: mattes
Was already going down the route with FlashMagic, but that got delayed due to its $WIN$ requirement.
No such things around here, except Linux.
I use lpc21isp for UART ISP under Linux.
3,218件の閲覧回数
Content originally posted in LPCWare by mattes on Tue Feb 25 17:08:17 MST 2014
Quote: LabRat
As shown here:
I tried this way before and was not successfull.
It started working for me when i left the ISP grounded until the uploading of the new code succeeded.
anyway thanks for all your advice, It's appreciated
3,218件の閲覧回数
Content originally posted in LPCWare by LabRat on Tue Feb 25 15:44:46 MST 2014
Quote: mattes
  powered up the board.
  grounded ISP pin [38 - PIO0.1]
  started upload via lpcxpresso, which failed
  then grounded RESET pin [4 - PIO0.0], and noticed that led LED2 went to half dim mode.
  now upload via lpcxpresso succeeded, but the debuuger did not start.
  removed ISP grounding wire
  grounded RESET pin one more time and now the debugger starts up
This is nearly the correct standard 'switch to ISP'...
As shown here:
Note: SPAM-Filter is hating youtube. So we have to change the 'X' to 'e'....
3,218件の閲覧回数
Content originally posted in LPCWare by mattes on Tue Feb 25 15:32:41 MST 2014
Anyhow, ran across the url today. LPC11U14 - Board recovery using the ISP pin
   http://docs.lpcware.com/lpcopen/v1.03/_l_p_c_o_p_e_n_11_x_x__b_o_a_r_d__x_p_r_e_s_s_o_11_u14.html
Not that this is stating anything much different from the codered instructions. But I thought I give it another spin.
Now the dev board works again, unbricked and I am happy.
Just a warning:
this board got unrogrammable after I succesfully uploaded the sample 'nxp_lpcxpresso_11u14_periph_pinint' (from lpcOpen2.0). The sample worked, but part of the code  puts the 11u14 into deep sleep.  (I think) Maybe that's what renders uploading then obsolote?
any ideas?
3,218件の閲覧回数
Content originally posted in LPCWare by LabRat on Sun Feb 23 12:53:44 MST 2014
Quote: mattes
I tried both. None of them worked for me.
Then it's time to use UART-ISP and FlashMagic...
3,218件の閲覧回数
Content originally posted in LPCWare by mattes on Sun Feb 23 12:15:44 MST 2014
Quote: LabRat
Quote: mattes
But It doesn't work for me.
Which one? Boot into UART ISP or into MSC?
3,218件の閲覧回数
Content originally posted in LPCWare by LabRat on Sun Feb 23 11:50:44 MST 2014
3,218件の閲覧回数
Content originally posted in LPCWare by mattes on Sun Feb 23 11:33:37 MST 2014
I heard/read about it, but yet have not been successful to manage it.
I followed NXP LPCxxxx ISP - http://support.code-red-tech.com/CodeRedWiki/DebugAccessChip
But It doesn't work for me. I must be doing something wrong.
3,218件の閲覧回数
Content originally posted in LPCWare by LabRat on Sun Feb 23 11:26:13 MST 2014
ISP  :quest:
