virtual com driver of LPC43xx on MacOS
1,237件の閲覧回数
lpcware
Content originally posted in LPCWare by JiaJun on Wed Apr 27 18:32:46 MST 2016
I want to use the virtual com on MacOS ,but I cannot find the dirver.
Thank you.
2 返答(返信)
1,225件の閲覧回数
lpcware
bump
1,225件の閲覧回数
lpcware
Content originally posted in LPCWare by vtw.433e on Thu Apr 28 00:56:36 MST 2016
You don't need a special driver for MacOS. It will 'just work'.
The device will be called something like /dev/tty.usbmodem*. One way to check will by to list all /dev/tty* devices before and after the virtual USB port is connected and seeing which new one appears.
