serial print problem
aravindpb5009
hai
   I got the ADC value  in LPC824   the value of adc is printing IDE console but when i try to send that value to serial UART it doesnt take i don't know why value is not accepting in serial . i tried to print the string in serial , string values what i send that properly transfer in my serial terminal  but the value only not printing in serial . please find my attachment how i used to send the serial values
Hello Aravind palanisamy ,
Please check whether use the same UART port in your code and hardware, check the pins in hardware.
You can first send a simple character to test UART.
Hope it helps,
TIC
aravindpb5009
OK
