reg:link server issue
faziya
I am working on SDK 2.5.0 now i am updated the SDK to 2.13 I am uanable to detect the link server probe
getting stuck while debugging ,the user operation is waiting.if any one know how to recover can u please reply me as early as possible
ZhangJennie
Hi faziya,
Please make sure you are using the latest version of MCUXpresso IDE v11.7.1 as well.
You can download it from this link
https://www.nxp.com/design/software/development-software/mcuxpresso-software-and-tools-/mcuxpresso-i...
If problem still exists, let me know your chip part number and if you can reproduce the issue with a demo board.
Jun Zhang
faziya
With demo project i am not getting the error, in the working project i am getting the error
i am using lpcxpresso54s018-evk board
ZhangJennie
Please check which Flash driver configuration file (*.cfg) is used in your project.
change Flash Driver to SPIFI_GENERIC, see how it works.
If this can't resolve your problem, send your demo project here, I will check it directly on my side.
Jun Zhang
faziya
I am using IDE version 11.7.0 ,same issue is repeated,while debugging link server probe is not detected
if i click debug i get stucked user operation is waiting.Suggest a way to reboot the boot.
chip no - LPC54S018JET180
If any one know the solution please reply me as early as possible
Thank You
ZhangJennie
Do you use nxp demo board or own PCB?
if custom PCB, did you ever connect it once before?
please test it with create a NEW project under a NEW workspace to avoid old associations.
Jun Zhang
