question about connection
milan021
I I have a microcontroller LPC5512 on my board, and I also have USB mini B for programming. When I connect USB to my computer, it does not recognize any port there. Do I need to install some drivers for it ? I also have your environment for it, and I manage to put code from the environment to development boards LPC55S16-EVK. Please, help me, I beg you.
Milan
_Leo_
Hello Milan,
You do not need to install any driver. What you can do is check the Hardware Design Guidelines for LPC55(S)xx Microcontrollers and Design Considerations for Debug to see if your board meets the design recommendations.
I hope this will help you. If you continue to have problems, please let me know so I can try to find another solution.
