problem with usb lite lib
1,585件の閲覧回数
Content originally posted in LPCWare by ali sd on Sat Mar 29 07:36:32 MST 2014
hi
recently i bought a board with lpc1788 micro on it,because it influence to communicate with usb mass storage device.
then i used nxp usb host lite lib for communicate with flash disk,
it receive dir from flash disk and read or write in it correctly,but i can not find any way to delete file or folder from flash.
any one can help me to do that .
  • USB
1,564件の閲覧回数
Content originally posted in LPCWare by drs on Fri Apr 04 10:37:32 MST 2014
We don't really support USBHOSTLITE.
Have you considered using LPCOpen Platform for this part? (http://www.lpcware.com/content/nxpfile/lpcopen-software-development-platform-lpc17xx-packages)
There is a host mode Mass Storage example in there which we do support. This example uses ChanFS which is a very comprehensive open source FAT driver that should do everything you need.
