problem with creating hex file in DS-5
lpcware
Content originally posted in LPCWare by prabhua86 on Tue Jan 12 02:14:35 MST 2016
hi,
    I'm new user from ds-5.I have created in sample project for lpc 1768 controller.compile for this project. but not created in axf file.I have tried to create hex file still not created. how do i convert axf and hex file please post in step by step screen shot .
lpcware
Content originally posted in LPCWare by whitecoe on Wed Jan 13 01:23:45 MST 2016
Without seeing how you are invoking fromelf and from where, its hard to say why you might be having problems.
But to be honest, you might have better luck posting on ARM's own forum for help on using DS-5. I suspect that most users on LPCware are LPCXpresso IDE, Keil or IAR users.
HTH!
lpcware
Content originally posted in LPCWare by prabhua86 on Tue Jan 12 23:10:50 MST 2016
hi,
    Thanks, I have already  tried for this format "fromelf" but cannot create file."system can not resolved" error comes in build time.
    how do i work in ds-5
lpcware
Content originally posted in LPCWare by whitecoe on Tue Jan 12 04:35:37 MST 2016
The tool ARM provide to convert ELF files (i.e. AXF's) to other formats is "fromelf". Check the ARM docs for more details.
HTH!
