open drain current of lpc5528
Eswarsai
what is the maximum current on open drain pins of LPC5528?. not mentioned in datasheet
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, maybe this information could help you.
The open drain correct will be the maximum of the MCU support, take in consideration this is the maximum.
Pavel
