need support for LPC1227 evaluation board
1,005 次查看
mnvnreddy
Need support for LPCXpresso™ Board for LPC1227 MCUXpresso IDE is not supporting this board how can i get the support. Is this controller production is active. How can i use this evaluation board.
991 次查看
Pablo_Ramos
As you stated MCUXpresso IDE do not support LPC1227, however, LPCXpresso IDE does, as you can see on the Supported Devices on the LPCXpresso IDE page
LPCXpresso IDE v8.2.2 | NXP Semiconductors
Also, IAR Embedded Workbench, Keil MDK and Keil Studio has it in their supported devices, however, I suggest you double check directly with them to ensure support of this device
Best Regards
Pablo
980 次查看
mnvnreddy
Hi Pablo,
Thank you for the quick response. I will try and let you know. Thanks once again.
