lpc54018 credit based shaper
6,368 次查看
wwang
Does LPC54018 support credit based shaper, if yes, how can I enable it ?
13 回复数
6,344 次查看
magicoe_niu
@william_jiang would you mind assign a guy support this case who knows Ethernet IP well?
The end customer is Microsoft
Thank you!
6,251 次查看
wwang
Hi Magicoe,
any update on this topic?
is there any special requirement for enabling CBS?
we run traditional iperf test on queue enabled CBS, and expect the throughput are limited by the idle slope. Is that reasonable?
6,356 次查看
xiangjun_rong
I do not think that the Ethernet module of LPC54018 supports credit based shaper.
Hope it can help you
XiangJun Rong
6,211 次查看
wwang
have you received the project I send out by e-mail?
thanks.
6,208 次查看
xiangjun_rong
Hi, Wang,
Can you clarify your requirement? do you hope that NXP engineer can help review your code, or you do not know how to use CBS feature of ethernet and hope to get support.
Pls clarify your requirements.
XiangJun Rong
6,198 次查看
wwang
1. if LPC54018 support CBS?
2. if yes, how to enable it.
if the question 2 is too complicate, let us ignore it.
I think just to clarify if LPC54018 supports CBS, that will be good enough.
6,187 次查看
xiangjun_rong
Hi, Wang,
This is the AE reply "LPC54018 supports CBS", but we have not the code to support the feature in SDK driver. I am sorry.
XiangJun Rong
6,335 次查看
wwang
Thanks for the information.
I just created the code based on the reference manual :  UM11060
LPC540xx/LPC54S0xx User manual.
and there are actually credit based shaper register on LPC54018
6,324 次查看
xiangjun_rong
Obviously, from the UM11060.pdf, the LPC54018 supports CBS, I will create a ticket for AE team, pls clarify your requirements so that the AE team engineer can help you
If you require  us to review the code, pls post it here or send to my personal Email if it is confidential.
XiangJun Rong
6,321 次查看
wwang
ok, i can send you the CBS code to review, can you tell me your email?
Do you have examples that show how to use CBS and how to validate the CBS function?
6,272 次查看
xiangjun_rong
I tried to contact you, but it appears that your Email address has issue. Pls check if the spelling is correct.
[email protected]
Xiangjun Rong
6,264 次查看
wwang
thanks for the effort, that email can't be accessed.
i will leave my personal email here: [email protected]
6,332 次查看
xiangjun_rong
Hi, Wang,
I appologize for the wrong information, I am not familiar with the CBS (credit based shaper) protocol.
We will give you a response after we discuss with AE team engineers.
XiangJun Rong
