lpc4330 lwip live streaming
Content originally posted in LPCWare by srinidhi M on Fri Aug 22 04:19:10 MST 2014
Hello ,
am trying to play PCM data using lpc4330 + ethernet + lwip(udp), getting noise while playing. am not getting how to avoid the noise.
Here is the call flow,
am using two threads one to receive packets from the network , and second one to transfer(DMA) the buffer to Hardware (Using ping pong buffer).
I am not getting where i am wrong, suggest me.
Thank you
Srinidhi M
Content originally posted in LPCWare by srinidhi M on Fri Aug 22 04:45:51 MST 2014
Hello ,
i am using I2S DMA mode (M2P) to transfer data from buffer to UDA, is there availability of UDA DMA mode ?
