lm75a temperature sensor
lpcware
Content originally posted in LPCWare by imroun1992 on Fri Sep 20 07:31:02 MST 2013
hello,
I want to read a temperature from lm75a with i2c lpc4357
thanks you
lpcware
Content originally posted in LPCWare by bavarian on Tue Sep 24 04:12:28 MST 2013
It's an example KEIL provides with their µVision environment for the MCP4300 board. Normally you find it here:
C:\Keil\ARM\Boards\Keil\MCB4300\Demo
In this demo software the I2C is used to read temperature values from LM75a.
NXP Support
lpcware
Content originally posted in LPCWare by capiman on Fri Sep 20 09:15:35 MST 2013
just do it! Where is the problem?
Martin
