help lpc1114/301
help lpc1114/301
1,169件の閲覧回数
lpcware
Content originally posted in LPCWare by omnitemporal on Thu Apr 12 04:34:27 MST 2012
Hi everybody,
I'm new about the cortex series microcontrollers. I have a coocox lpc programmer and i tried to write a simply program which contains only one input and one output. İf i press the switch i want to turn the led on. Can anyone help me how i set the related registers? Thanks for your help .
1,160件の閲覧回数
lpcware
Content originally posted in LPCWare by drs on Thu Apr 12 12:22:21 MST 2012
You will find lots of example code for this part here: http://www.lpcware.com/content/nxpfile/sample-code-bundle-lpc11xx-peripherals-using-keils-mdk-arm
