fsl_fro_calib source code
saltyJeff
Due to errata USB.1 in ES_LPC5411x, the workaround in TN00031 is required to implement crystal-less USB across multiple USB hubs. I am looking into supporting multiple serial ports from a single device. However, the sample in the SDK (usb_device_composite_cdc_vcom_cdc_vcom) doesn't seem to reference the fsl_fro_calib or TN00031 errata anywhere? Is there source code available for the fsl_fro_calib library in TN00031 so I can port it? If not, how can I have multiple serial ports enumerate from a LPC5411x across multiple hubs?
ZhangJennie
Please let me know SDK and IDE version. I will check.
Jun Zhang
saltyJeff
I'm using MCUXpresso SDK 2.9, with my own editor (vs code) and toolchain
ZhangJennie
HI saltyJeff
Please create a private ticket to NXP support team to request the source code.
Please specify your project related informaiton.
https://support.nxp.com/s/?language=en_US
Jun Zhang
