flash programming + IAP
830件の閲覧回数
lpcware
Content originally posted in LPCWare by pinkesh on Tue Aug 12 08:05:16 MST 2014
Hi,How are you?
In LPC2129 device, I want to save 100 bytes in free flash sector during runtime, so for that I need code example for flash programming using application code. Also I need document which gives idea of mapping of flash for this device only.
It would be helpful if you can provide all example code or weblink for same device.
0 返答(返信)
