example code for multiple channel adcs
Alex_2221
Hello everyone, I'm trying to read temperature from LM35 through ADC. I'm also using ADC interrupt. I want to read another temperature from another channel, but I receive a constant number from the other channel! could you please give an example source code with ADC interrupt and several ADC channels?
xiangjun_rong
Can you tell us the micro-controller part number to read temperature sensor via ADC and post the project so that we can have a review?
XiangJun Rong
Alex_2221
By the way I  had a problem with this project and asked you about it, but finally I resolved this issue. It was due to bad soldering and not the code. However, I'm eager to optimize my code and use more functions. In the case of facing problems can I reach out to you?
xiangjun_rong
XiangJun Rong
Alex_2221
Hi, thanks for the reply. I'm using LPC1768
