emWin precompiled libraries by NXP: compilation details?
lpcware
Content originally posted in LPCWare by giusloq on Wed Jan 20 07:39:57 MST 2016
I'm sure the info I'm asking is somewhere, but I couldn't find it.
NXP releases emWin precompiler libraries for their MCUs. It's important to know exactly how they are compiled (compiler options, linker options, macros, ...).
lpcware
Content originally posted in LPCWare by giusloq on Sat Feb 13 09:01:46 MST 2016
Quote:
Please check another thread
https://www.lpcware.com/content/forum/can-i-get-emwin-precompiled-library-no-size-restrictions
Nothing special is written in that thread, except the link to the official NXP emWin library distribution: https://www.lpcware.com/content/project/emwin-graphics-library
Even in that page, I couldn't find any detailed info about the compilation process of pre-compiled libraries distributed by NXP, except the following minimal sentence:
Library is complied for multitasking(GUI_OS=1) with maximum number of tasks equal to four (GUI_MAXTASK = 4).
lpcware
Content originally posted in LPCWare by mc on Fri Feb 12 12:39:10 MST 2016
lpcware
Content originally posted in LPCWare by mcuevas on Thu Jan 21 09:14:02 MST 2016
I agree with you,  I just found out that EMWIN precompiled library has size restrictions on the size of my program. Whenever I use emWin_ARM7TDMI.a I get an error on my IAR system saying “Size limit exceeded (262 144 bytes).
I have the “STD” license from IAR; I should not be having size restrictions problems. I call IAR technical support to find out why I was having this error, and it turns out that  emWin_ARM7TDMI.a was compiled under the “BL” AIR license which only allows  262 144 bytes.
https://www.iar.com/support/tech-notes/general/code-size-limitation-persist/
Tested: When I replace emWin_ARM7TDMI.a for SEGGERDEMOv5_ARM_IAR_V5_4t_tl_ir.a (Trial version from SEGGER) my program compiles fine.
Can you provide me with a EMWIN precompiled library with no size restrictions?
