Where to send bug fixes for lpc175x_6x.git ?
lpcware
Content originally posted in LPCWare by mburton on Tue Nov 06 03:46:50 MST 2012
I have only just discovered lpcware and so I am completely new here.
I work on a project that uses the lpc1758.
Until recently I have been using an ancient version of LPC1700CMSIS but having now discovered lpc175x_6x.git, I have started using that instead. In getting it to build on a Linux box I needed to make a couple of tweaks so I would like to submit them for incorporation. Where do I send patches to?
Also, I am now using gcc 4.6.2 (from https://launchpad.net/gcc-arm-embedded) and libnosys rather than the cs3 stuff and have some diffs related to that (config tweaks + new ld script and startup code) if anyone is interested. If so, where should I post that, here?
Cheers,
Mark
lpcware
Content originally posted in LPCWare by Lien.Nguyen on Tue Nov 06 20:01:41 MST 2012
Hi Mark,
If you found bugs, you can post it on Bug Tracker (http://www.lpcware.com/ct_plus/filter).
Lien
