Where's the WRAPEN field?
2,859件の閲覧回数
ianbenton
Senior Contributor I
In table 434 of the LPC15xx manual, regarding the INSEL regiseter, where is the WRAPEN field?
4 返答(返信)
2,660件の閲覧回数
kerryzhou
Hi Lan Benton,
    Thanks a lot for your patience.
    I got the reply:
The information should be removed from the user manual since this is for internal use only.
The updated UM will go on the web in next few days.
  So, please ignore the WRAPEN  field.
Kerry
2,660件の閲覧回数
ianbenton
I look forward to seeing the new manual (and its extensive corrigenda)
2,660件の閲覧回数
ianbenton
Hurrah! The corrected manual has arrived! But the section on the I2C pins is still wrong:
 Pins PIO0_22 and PIO0_23 operate as high-current sink drivers (20 mA) independently of
the programmed function.
They don't - you only get high current output if programmed for I2C fast mode.
2,660件の閲覧回数
kerryzhou
Hi Lan Benton,
    About the WRAPEN, I also didn't find it.
   I already check it with our according department, any updated information will let you know.
   Please keep patient, thanks a lot for your understanding.
Kerry
