Vector Catch
Vector Catch
lpcware
Content originally posted in LPCWare by chaitanyapraveen on Wed May 11 07:47:45 MST 2016
I am a newbie. I am using lpcxpresso LPC1769 board along with baseboard and using lpcxpresso IDE to build and debug. I recently faced a problem in downloading the code into my board after enabling the watchdog timer in the code. I followed https://www.lpcware.com/content/faq/lpcxpresso/regaining-debug-access link to regain the debug access. There is option in the launch configuration menu named vector catch. I had to enable it to regain the debug access. I am very keen to know little bit about it. So, I tried search about it and could found any clue about. Could any one help me knowing about it.
Thank You
lpcware
bump
