Upgraded replacement for LPC4088FET208
deepaktajanpure
We are currently using the LPC4088FET208 microcontroller in our product and are looking for an upgraded or newer replacement device.
Our key requirement is to minimize software changes, so we are particularly interested in:
1. Pin-compatible or highly compatible alternatives
2. Devices with the same core (or upward-compatible core) and peripheral set
3. Compatibility with existing drivers, and toolchains
Could you please advise Recommended replacement or migration path from LPC4088FET208.
Deepak
Harry_Zhang
Hi @deepaktajanpure
For minimal change:
Select the LPC4088 version that best fits your packaging needs—such as the FET208 if board constraints or supply issues are package-related.
If you seek performance improvements, i think you can select MCX or IMX RT series.
Hope this will help you.
Harry
%3CLINGO-SUB%20id%3D%22lingo-sub-2265673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUpgraded%20replacement%20for%20LPC4088FET208%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2265673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CBR%20%2F%3EWe%20are%20currently%20using%20the%20LPC4088FET208%20microcontroller%20in%20our%20product%20and%20are%20looking%20for%20an%20upgraded%20or%20newer%20replacement%20device.%3CBR%20%2F%3EOur%20key%20requirement%20is%20to%20minimize%20software%20changes%2C%20so%20we%20are%20particularly%20interested%20in%3A%3CBR%20%2F%3E1.%20Pin-compatible%20or%20highly%20compatible%20alternatives%3CBR%20%2F%3E2.%20Devices%20with%20the%20same%20core%20(or%20upward-compatible%20core)%20and%20peripheral%20set%3CBR%20%2F%3E3.%20Compatibility%20with%20existing%20drivers%2C%20and%20toolchains%3C%2FP%3E%3CP%3ECould%20you%20please%20advise%20Recommended%20replacement%20or%20migration%20path%20from%20LPC4088FET208.%3C%2FP%3E%3CP%3ERegards%2C%3CBR%20%2F%3EDeepak%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2267666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Upgraded%20replacement%20for%20LPC4088FET208%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2267666%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F225696%22%20target%3D%22_blank%22%3E%40deepaktajanpure%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EFor%20minimal%20change%3A%3C%2FP%3E%0A%3CP%3ESelect%20the%20LPC4088%20version%20that%20best%20fits%20your%20packaging%20needs%E2%80%94such%20as%20the%20FET208%20if%20board%20constraints%20or%20supply%20issues%20are%20package-related.%3C%2FP%3E%0A%3CP%3EIf%20you%20seek%20performance%20improvements%2C%20i%20think%20you%20can%20select%20MCX%20or%20IMX%20RT%20series.%3C%2FP%3E%0A%3CP%3EHope%20this%20will%20help%20you.%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EHarry%3C%2FP%3E%3C%2FLINGO-BODY%3E
