Unused xtal pins
Unused xtal pins
1,465 次查看
richardsoennich
Does NXP offer any guidelines on what to do with unused xtal pins?  (LPC1114)
Rich
1 回复
1,347 次查看
soledad
Hi Rich,
When the system oscillator is not used, connect XTALIN and XTALOUT as follows: XTALIN can be left floating or can be grounded (grounding is preferred to reduce susceptibility to noise). XTALOUT should be left floating.
I hope this helps,
Sol
