USB fails to enumerate after disconnect
lpcware
Content originally posted in LPCWare by chrissweet on Mon Sep 28 20:11:31 MST 2015
    I am using lpcopen 2.10 on a LPC4088 Embedded Artists Developers Kit. Running the Virtual Com port example works fine but if I disconnect the USB and re-connect the connect light flashes then goes off and it fails to connect. Anyone have any ideas on this?
