Timeout
Timeout
1,402件の閲覧回数
asafbrosh
Trying to understand the following phenomenon -
Starts working with the lpc_1758 when the host is connected (the micro is device). At one point the host is disconnected physically from micro and micro continues to work independently.
After about 80 minutes the micro reset itself.
Is there a timeout to USB? After a certain time is not connected to the host the micro is trying again to communicate? How can I disable it?
Thx
Asaf
ラベル(2)
1,316件の閲覧回数
soledad
Are you using a NXP board? Are you using a example code?
Sol
