TCPIP on LPC1837
TCPIP on LPC1837
jan92
Hi, I wanted to try the the lwip_tcpecho example code from lpcopen on the board with lpc1837. The problem is that the code always end with hardfault: in function void lpc_enetif_input(struct netif *netif).
Thanks for any help.
Jan
jeremyzhou
Hi Jan Hakl ,
for the opportunity to serve you.
I was wondering if you share a build-able demo, then I can replicate the phenomenon on my site.
TIC
jan92
Solved. It was due to wrong LCPopen examples... I tryed the example for nxg board and it worked.  Thanks
