Strange behavior LPC2364
772件の閲覧回数
lpcware
Content originally posted in LPCWare by bejacques on Wed Jul 15 07:48:26 MST 2015
Hi all!
I'm dealing with a strange behavior with LPC2364. When the voltage supply drops approximately to 0.5V and back on to nominal, some pieces of LPC2364 are crashing. In this situation, the reset pin does not make any effect and the reset_out pin stay in 0V. The only way to return normal operation is switch off and switch on again the power supply. Did someone have some idea?
0 返答(返信)
