Static power of board
1,356件の閲覧回数
v_a_kulkarni
I am using LPC 54102 to my project software power estimation. How to disable/idle all on chip peripherals keeping core active ? What is the current taken by board when all peripherals and core is in idle state (static power)?
1,205件の閲覧回数
soledad
Please check the AN11607. This application note describes how to adapt the provided framework projects to run CoreMark benchmark tests on the Cortex-M4 core of the LPC5410x. Different project configuration options for best CoreMark number and μA/MHz are discussed.
http://cache.nxp.com/documents/application_note/AN11607.zip?fsrch=1&sr=1&pageNum=1
Sol
