SPI slave without using ROM API
lpcware
Content originally posted in LPCWare by vikas.javkar on Wed May 20 06:52:45 MST 2015
Hello Guys,
I am quite new to LPC and currently working on LPC15XX series controller. I am trying to write my own SPI slave implementation and I can't  to use ROM APIs since I need to use it in 8-bit mode and have few other slave requirements.
Has anybody tried this? If yes can someone post the sample code?
Thanks in advance.
- Vikas J
lpcware
Content originally posted in LPCWare by vikas.javkar on Fri May 29 06:38:20 MST 2015
Hello Guys,
Finally I am able to write and test the SPI slave code successfully.
Thanks for your help.
Vikas
