SPI data length: Error description in LPC845.h
1234567890
The bit discription doesn't match the bit length. In the text it is correct, in the 'table' below not: 0b0001 does not code 1 bit in length. This made me busy for about 25 minutes until I opened the User Manual...
Hello 12345 67890,
Yes, you are right, thanks for your sharing,i will submit it to SDK team.
Alice
