SCT For Capture
SCT For Capture
lpcware
Content originally posted in LPCWare by celephicus on Sun Nov 16 16:01:31 MST 2014
There is an error in the docs. In UM10736 (LPC15xx User Manual) Rev 1.1 on p234 the description for the REGMODEx registers is WRONG:
"The REGMODEn bits in the REGMODE register determine whether each set of
Match/Capture registers uses the match or capture functionality:
– REGMODEn = 1: Registers operate as match and reload registers.
– REGMODEn = 0: Registers operate as capture and capture control registers.
But on P246 it gets it right:
"Each bit controls one pair of match/capture registers (register 0 =
bit 0, register 1 = bit 1,..., register 15 = bit 15).
0 = registers operate as match registers.
1 = registers operate as capture registers.
So far we have got match working but we have not been able to get input capture going.
lpcware
Content originally posted in LPCWare by R2D2 on Tue Nov 18 05:11:39 MST 2014
Quote: MarcVonWindscooting
I don't know if there is an English equivalent to the German (swear-) word 'Wizard-Gebimsel'.
If so, I'd like to know it ;-)
Try 'kerfuffle'   :)
lpcware
Content originally posted in LPCWare by MarcVonWindscooting on Tue Nov 18 04:32:13 MST 2014
Quote: LabRat
Quote: R2D2
Quote: celephicus
I'm curious, do people manually configure the SCT or do they use RedState?
We do it manually...
+1  :)
+ another one  :bigsmile:
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Mon Nov 17 12:15:00 MST 2014
Please note that the latest version of the User Guide can be found here:
http://www.lpcware.com/content/nxpfile/lpcxpresso-ide-v7-user-guide
lpcware
Content originally posted in LPCWare by mc on Mon Nov 17 09:55:00 MST 2014
Hi celephicus,
As LabRat mentioned manually it may not be that easy. You can also look below red state tool.
http://support.code-red-tech.com/CodeRedWiki/NewInVersion4?action=AttachFile&do=get&target=Red_State...
Edit: Above document is old doc so you can refer to page 86 onward at below link
http://www.lpcware.com/system/files/LPCXpresso_User_Guide.pdf
For latest documentation you can always download LPCxpresso.
lpcware
Content originally posted in LPCWare by LabRat on Mon Nov 17 03:38:51 MST 2014
+1  :)
lpcware
Content originally posted in LPCWare by R2D2 on Mon Nov 17 01:44:41 MST 2014
We do it manually since march...
lpcware
Content originally posted in LPCWare by R2D2 on Mon Nov 17 01:44:39 MST 2014
lpcware
Content originally posted in LPCWare by celephicus on Sun Nov 16 22:28:47 MST 2014
We got capture working, just a bit of confusion between event numbers and channel numbers. And for some reason I was looking for the capture result in MATCHREL instead of CAP register.
lpcware
Content originally posted in LPCWare by celephicus on Sun Nov 16 19:54:43 MST 2014
Not clear? Contradictory!
Anyway thanks for the reply and we will look at the example. Setting up the SCT is a bit of a steep learning curve, at least compared with conventional timers that have output compare, PWM or input capture, and that's the lot.
lpcware
Content originally posted in LPCWare by mc on Sun Nov 16 17:37:00 MST 2014
Hi celephicus,
That statement indeed not clear. There are match and match reload registers and capture and capture control registers.
There is a cookbook at
http://www.nxp.com/documents/application_note/AN11538.zip. This example shows capture example.
Check  RC5 receiving example at page 31/34 in this application note.
lpcware
Content originally posted in LPCWare by R2D2 on Sun Nov 16 16:13:25 MST 2014
Capture is working fine  :)
What did you try already?
