Running LPCUSBLib_SerialHost on LPC43xx (OM13084)
1,309 次查看
omidathari
I am trying to run the LPCUSBLib_SerialHost program on the OM13084 board not having any luck.
When I plug in my Trendnet usb serial device, the there is an error in finding and enumurating routine
and CDC_ENUMERROR_NoCompatibleInterfaceFound is returned.  Therefore the interface is not enabled.
//CDCClassHost.c line 202
if (USB_GetNextDescriptorComp(ConfigDescriptorSize, ConfigDescriptorData,
DCOMP_CDC_Host_NextCDCControlInterface) != DESCRIPTOR_SEARCH_COMP_Found)
return CDC_ENUMERROR_NoCompatibleInterfaceFound;
Any ideas
Omid Athari
1,118 次查看
soledad
Hello Omid,
Please check the below threads and let know if this helps,
How to use Lpc4330 as usb cdc host | www.LPCware.com
USB Host CDC Example
Sol
