Reprogrammnig the LPC812
lpcware
Content originally posted in LPCWare by hakljn on Thu Oct 22 05:48:04 MST 2015
Iam using a project where is a watchdog. When I program the LPC812 using LPC Link-2 first, it work. Problem is when I need to reprogram it. Is there any way how to erase the flash and reprogram it?
Thanks!
lpcware
Content originally posted in LPCWare by Wojtkingson on Mon Nov 02 06:36:03 MST 2015
it´s pretty common.
Try to use
https://www.lpcware.com/content/faq/lpcxpresso/gui-flash-programming-tool
You can just erase whole flash without entering into the ISP mode, but it works too.
lpcware
Content originally posted in LPCWare by embd02161991 on Fri Oct 30 19:11:23 MST 2015
Please try entering the ISP mode and erase/program the flash again.
NXP Technical Support
