RTOS and openSSL support for LPC43S67
5,589件の閲覧回数
zhouhaohua
what kind of RTOS has been test on LPC43S67, uC/OSII,FreeRTOS, any experience to share? where to get the A70CM Host API, so I can access A70CM for security related application, I have NXP-Cloud kits, which have A7001 and LPC43S67 on the board,
   any experience to Porting openSSL to LPC43S67 and work with A70CM?
タグ(1)
7 返答(返信)
5,069件の閲覧回数
jeremyzhou
Hi Charlie,
Thank you for your interest  in NXP Semiconductor products and the opportunity tor serve you.
1) What kind of RTOS has been test on LPC43S67, uC/OSII,FreeRTOS, any experience to share?
   I'd like to recommend you to refer the LPCOpen library which contains some RTOS demos.
LPCOpen Software for LPC43XX|NXP
2) Where to get the A70CM Host API, so I can access A70CM for security related application?
   As I know, if customer want to get A70 security support, they need signed a special NDA with NXP. This need check with A70 product line. Customer can check this with the distributor and you can learn the contacting information through the link below:
Distributor Network|NXP
Ping
5,069件の閲覧回数
zhouhaohua
I mean some popular RTOS like freeRTOS, don't have too much time to spend
on RTOS, need some generic one, so I can easy ported the SW
5,069件の閲覧回数
jeremyzhou
Hi Charlie,
Thanks for your reply.
Let me clarify it, the LPCOpen Software for LPC43XX|NXP contains a FreeRTOS template demo.
It can help you to get start with the FreeRTOS.
Ping
5,069件の閲覧回数
zhouhaohua
Dear Ping:
How about SSL/TLS examples?
On Thu, Jan 19, 2017 at 10:03 PM, jeremyzhou <[email protected]>
5,069件の閲覧回数
jeremyzhou
Hi Charlie,
I haven't found these demos which is about SSL/TLS.
However you can go to Cypherbridge Systems Products & Services  to find the information you request.
Hope it helps.
Ping
5,069件の閲覧回数
zhouhaohua
I am interested in using ARM mbed OS and TLS to test https not http , so I
can use it to do some https access examples, do you have similar
examples,
but I don't know what is the step to make https work
LWIP FreeRTOS TCP Echo example
Example description
Welcome to the LWIP TCP Echo example with FreeRTOS using the 18xx/43xx LWIP
MAC and PHY drivers. The example demonstrates PHY link monitoring, DHCP
client, ICMP Echo (ping) and TCP Echo (RFC 862) operation.
5,069件の閲覧回数
rocketdawg2
i could be wrong, but I think it is included with the dev board
LPC43S67-A70CM Cloud Connectivity Kit|NXP
