PCF7945MC2200
PCF7945MC2200
Aga74
Hi everyone,
I need data sheet of PCF7945MC2200.
Can someone help me?
the PCF7945MC2200 is an integrated circuit that is mounted on a renault capture card. Since the card was not recognized by the car, I disassembled the card and re-welded the inductor which was causing problems.
Now the card is being disowned.
However, when disassembling the card I damaged some components around the F7945MC2200 and now the remote control doesn't work. If I could get the integrated wiring diagram I would restore everything.
thnaks
Veronika_techsupport
Hello @Aga74
PCF7945MC2200 is not correct NXP part number. If this device was found in an end product, please contact the manufacturer of the product or equipment for information.
Thank you
