OM26630FDK Cockpit firmware update
kadirsevil
I have OM26630FDK NFC Frontend Development Kit, i uploaded and tried several nfc reader library examples, now i want to use this board with NFC Cockpit. How can i upload firmware to make this board run with NFC Cockpit?
Regards.
Fabian_R
Hello sir,
Since this is a front-end reader, it requires a binary file to be flashed through MCUXpresso + LPC-Link2. This is mentioned in the CLRC663 Quick Start Guide (section 3). But, I will recommend you to please check the UM10954, even though is the PN5180 Quick Start guide but, has a step by step guidelines on how-to flash a front-end board in section 5. (Flashing firmware on the LPC1769)
Fabian
Fabian_R
Hello sir,
Fabian
kadirsevil
Thank you.
