Not Debug projects
Not Debug projects
VijayaJangam1
I had include LPC24xx.h file in the project and starting with LED program but  I had faced problem in Debugging there is not properly Debug the project What I should do next please guide me. I have sending the document in that mention all things
EdwinHz
Hi @VijayaJangam1,
Unfortunately, the LPC24xx and LPCXpresso are no longer actively supported. What I could recommend is to erase the LPC using an application like Flash Magic, and then try to upload an example code that you know works properly, before trying to load your application again.
