Movable function input behavior when it swithed by switch matrix
2,142 次查看
alexeyborisenko
Which level movable function see when it disconnected from any pin by FF?
Can I assume that switching of input function between pins is clean, without glitch pulses inroduced by SWM?
标记 (1)
3 回复数
2,044 次查看
kerryzhou
Hi Alexey,
   About this movable function level, we don't have the test data defined in the datasheet.
   But, if you have interest, I think you can test it by yourself on your side, I don't think this point will influence your usage.
  Anyway, If you have the problem in your practical usage about this point, please kindly let us know.
Kerry
2,044 次查看
alexeyborisenko
I prefer to not rely on any undefined behavior at all, but when I trying to assume that all that not clearly defined in official datasheet and user guide is undefined, I become frustrated because too many features of LPC microcontrollers become not useful for my needs only because of lack of clear definitions in those official documents. I believe that engineereing staff of NXP will work on that documents to resolve this problem, but I not see any significant advances in thtis direction over years. :smileysad:
2,044 次查看
kerryzhou
Hi Alexey Borisenko,
  Sorry for the inconvenience we bring you.
  If you don't want to test, please tell me the chip which you want to use, I would like to help you to test it on my side. But this data is just for your reference, different work condition may have difference.
Kerry
