Mikrobus interrupts target connection
1,242 次查看
BerkantCiftci2001
Hi all,
I am working on a project with the lpcxpresso55s16-evk. I am using the gsm/gnss 2 click expansion card from MikroE. After clicking this in, I cannot connect to the target nor debug. I know that the expansion slot shares the UART with the target, but is there any way to make this work while it is connected? e.g. with the jumper configuration? I was looking into the documentation, but no luck.
Kind regards
标记 (3)
1,224 次查看
ZhangJennie
Hi BerkantCiftci2001
We never use/test gsm/gnss 2 click expansion card  thus we can't reproduce your issue.
I just you try external debug probe for example MCU-Link for test. It uses SWD interface.
Have a nice day,
Jun Zhang
