MbedTls version change
ahmed007
How can I chagnethe mbedtls library to version 3.0.0? Currently, I am using the mbedtls library from the SDK_2.13.0_LPCXpresso55S16. Does anyone have suggestions or instructions on how to proceed?
the SDK contains the following middleware : mbedTLS
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, in order to know more about your case, what kind of version do you need? you can try to download an older version of the SDK.
Pavel
