MKE04VTG4 controller
TEMCEFF
Sir, we are taking ADC sample for every 3 msec, in that case we getting o count at some instance (only for sample), even the applied voltage is remained same.
This is observed many times. Attached is the sample graph where one sample got low value when 2000 samples have been taken. Similar readings are observed.
Labels (2)
TEMCEFF
Hi Alexis,
I am using only one ADC.
Single conversion method.
only 1 or 2 among 2000 samples @ 3msec sample each.
Interrupt for ADC.
Muralidhar
Alexis_A
Hello keerthisripallapothu‌,
One more question, are you using a custom board or is one of our development boards? And if you're using the first one would it be possible to try to replicate this in one of our development boards?
Alexis Andalon
Alexis_A
I have some question about this:
Are you using other ADC channels in your project?
Are you using single conversion or continuous conversion?
How many samples are the ones at 0 or is a single one?
Are you using interrupts?
Alexis Andalon
