MFRC522 and LPC2148 code
omkar787898
I have MFRC522 and i can use it with Arduino but i want to use with LPC2148, MFRC522 datasheet has registers and commands but i am looking for steps to make it work. Is there any sample code for LPC2148 and MFRC522?
Labels (4)
jamesbone
Hello Omkar,
This is a link to an example project using the LPC1748, at the end are the same steps that you need to follow using the LPC2148 with the MFRC522
SPI Communication with MFRC522 | www.LPCware.com
