Hi support, I have version MCUXpresso IDE v10.2.0 [Build 759] [2018-05-15].
I created a new workspace and a new one project for LPC1769 expresso too.
When I try debug it the following error appears:
Please, could you help me?
BR!
Mariano
已解决! 转到解答。
Hi Mariano,
I already gave the engineering team a heads up.
Thanks for your files. But they do not include the launch configs.
Can you turn on 'shared file' (see Sharing Debug Configuration with Eclipse | MCU on Eclipse )?
Just a wild guess: maybe this is your problem, that you don't have the launch config stored as physical file? It should work that way too, but I'm always using 'shared file'.
I hope this helps,
Erich
Hi guys,
I am also getting similar Null Pointer Exception when I try to edit the debug configurations in S32 Design Studio. Infact I am not able to add new debug configuration at all.
Some of the observation which might be useful:
1. This is happening for all the projects
2. Launch configuration files are added in the version control system
3. I deleted the configuration and now I cant even add the configuration
I think it has something to do with the metadata folder present in the workspace. Any help towards resolving this is appreciated.
Prasanna
Hi Mariano,
We have imported your workspace onto a local test machine and see debug working without issue.
The logs you have supplied show a problem locating require files ...
Please can you tell us which host and version (linux, win etc.) you have installed MCUXpresso IDE onto. Also, is your workspace located on the same machine as this installation?
We can see file references at: /home/juliancho/Documentos/Facultad/InfoII/R2052/2018/Sources/LPC1769/Workspace2018/Eje2/Debug/../src/Eje2.c"
Yours,
MCUXpresso IDE Support
Hi dear support,
Thank you for your reply.
I'm using Debian 9.4 OS (natively).
My workspaces in general aren't in the same location of IDE installation.
A couple hours ago, I responded to Erich that my trouble was fixed with his last recommendation:
With "shared file" in the debug configuration.
Thank you for everything!
Mariano
I would delete the launch configuration and try again (with probe discovery), maybe your launch configuration somehow is bad. But as you have a new workspace and a new project that might not be the problem.
Does it happen for a different project too?
The other thought I have: can you check or post the .metadata/.log file inside your workspace?
I hope this helps,
Erich
Hi Erich, thank you so much for your help.
Yes, it happens with other new project too that I created in the same workspace or new one.
The log file shows this:
!SESSION 2018-07-17 20:15:32.106 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_161
java.vendor=Oracle Corporation
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=es_AR
Command-line arguments: -os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.jface 2 0 2018-07-17 20:15:42.992
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2018-07-17 20:15:42.992
!MESSAGE A conflict occurred for CTRL+U:
Binding(CTRL+U,
ParameterizedCommand(Command(com.nxp.swtools.clocks.commands.unlockAll,Unlock All Settings,
Category(org.eclipse.core.commands.categories.autogenerated,Uncategorized,Commands that were either auto-generated or have no category,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@30a4a111,
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
Binding(CTRL+U,
ParameterizedCommand(Command(org.eclipse.jdt.debug.ui.commands.Execute,Execute,
Evaluate selected text,
Category(org.eclipse.debug.ui.category.run,Run/Debug,Run/Debug command category,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@7f6a6d46,
,,true),null),
!ENTRY org.eclipse.launchbar.core 2 0 2018-07-17 20:15:45.906
!MESSAGE Enablement expression is missing for descriptor type org.eclipse.cdt.debug.core.coreBuildDescriptorType
!ENTRY org.eclipse.launchbar.core 2 0 2018-07-17 20:15:45.922
!MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2018-07-17 20:15:46.353
!MESSAGE Recreating part support. No part support available.
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2018-07-17 20:16:03.931
!MESSAGE No repository found at http://download.gna.org/eclox/update.
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2018-07-17 20:16:11.314
!MESSAGE HTTP Server 'Service Unavailable': http://gnuarmeclipse.sourceforge.net/updates/content.xml
!STACK 1
org.eclipse.ecf.filetransfer.BrowseFileTransferException: HttpComponents connection error response code 503.
at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:293)
at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:56)
!SUBENTRY 1 org.eclipse.ecf.identity 4 0 2018-07-17 20:16:11.316
!MESSAGE HttpComponents connection error response code 503.
!ENTRY org.eclipse.cdt.core 1 0 2018-07-17 20:16:21.504
!MESSAGE Indexed 'Eje1' (3 sources, 2 headers) in 0,555 sec: 149 declarations; 153 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0 %)
!ENTRY org.eclipse.core.jobs 4 2 2018-07-17 20:16:38.655
!MESSAGE An internal error occurred during: "Launching Eje1 Debug".
!STACK 0
java.lang.NullPointerException
at com.crt.dsfdebug.dsf.override.CRTGdbLaunchDelegate.getLaunch(CRTGdbLaunchDelegate.java:91)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:812)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:739)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1039)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1256)
!SESSION 2018-07-18 07:29:44.891 -----------------------------------------------
!ENTRY org.eclipse.jface 2 0 2018-07-18 07:30:18.728
!SUBENTRY 1 org.eclipse.jface 2 0 2018-07-18 07:30:18.728
Binding(CTRL+U,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@75566f4,
,,true),null),
Binding(CTRL+U,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@6785786d,
,,true),null),
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2018-07-18 07:30:27.676
!ENTRY org.eclipse.launchbar.core 2 0 2018-07-18 07:30:30.399
!ENTRY org.eclipse.launchbar.core 2 0 2018-07-18 07:30:30.406
!ENTRY org.eclipse.launchbar.core 2 0 2018-07-18 07:30:30.407
!ENTRY org.eclipse.core.jobs 4 2 2018-07-18 07:30:43.423
!STACK 0
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2018-07-18 07:30:57.630
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2018-07-18 07:31:07.564
!STACK 1
!SUBENTRY 1 org.eclipse.ecf.identity 4 0 2018-07-18 07:31:07.566
!SESSION 2018-07-18 07:31:18.165 -----------------------------------------------
!ENTRY org.eclipse.jface 2 0 2018-07-18 07:31:27.612
!SUBENTRY 1 org.eclipse.jface 2 0 2018-07-18 07:31:27.612
Binding(CTRL+U,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@3c34c491,
,,true),null),
Binding(CTRL+U,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@509e4902,
,,true),null),
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2018-07-18 07:31:29.877
!ENTRY org.eclipse.launchbar.core 2 0 2018-07-18 07:31:30.684
!ENTRY org.eclipse.launchbar.core 2 0 2018-07-18 07:31:30.689
!ENTRY org.eclipse.launchbar.core 2 0 2018-07-18 07:31:30.690
!ENTRY org.eclipse.equinox.p2.updatechecker 4 0 2018-07-18 07:32:01.578
!MESSAGE Exception in update check thread
!STACK 0
org.eclipse.core.runtime.OperationCanceledException
at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryTransport.download(RepositoryTransport.java:125)
at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryTransport.download(RepositoryTransport.java:156)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:735)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:657)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.addChild(CompositeMetadataRepository.java:166)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.<init>(CompositeMetadataRepository.java:106)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.load(CompositeMetadataRepositoryFactory.java:122)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:768)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:668)
at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker.getAvailableRepositories(UpdateChecker.java:152)
at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker.checkForUpdates(UpdateChecker.java:130)
at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker$UpdateCheckThread.run(UpdateChecker.java:74)
!SESSION 2018-07-21 08:40:12.292 -----------------------------------------------
!ENTRY org.eclipse.jface 2 0 2018-07-21 08:40:58.616
!SUBENTRY 1 org.eclipse.jface 2 0 2018-07-21 08:40:58.617
Binding(CTRL+U,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@528c4353,
,,true),null),
Binding(CTRL+U,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@1a06b95,
,,true),null),
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2018-07-21 08:41:06.203
!ENTRY org.eclipse.launchbar.core 2 0 2018-07-21 08:41:07.745
!ENTRY org.eclipse.launchbar.core 2 0 2018-07-21 08:41:07.748
!ENTRY org.eclipse.core.jobs 4 2 2018-07-21 08:41:23.783
!STACK 0
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2018-07-21 08:41:31.137
!SESSION 2018-07-22 08:53:29.774 -----------------------------------------------
!ENTRY org.eclipse.jface 2 0 2018-07-22 08:54:24.766
!SUBENTRY 1 org.eclipse.jface 2 0 2018-07-22 08:54:24.766
Binding(CTRL+U,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@7f958d4a,
,,true),null),
Binding(CTRL+U,
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@6af29394,
,,true),null),
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2018-07-22 08:54:33.368
!ENTRY org.eclipse.launchbar.core 2 0 2018-07-22 08:54:35.260
!ENTRY org.eclipse.launchbar.core 2 0 2018-07-22 08:54:35.261
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2018-07-22 08:54:58.886
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2018-07-22 08:57:35.701
!MESSAGE Using manifest XSD 'rsc/manifest_v3.3.xsd' for manifest '/usr/local/mcuxpressoide-10.2.0_759/ide/plugins/com.nxp.mcuxpresso.core.datamodels.resources_10.2.0.201805151128/fragments/ksdk_manifest.xml'.
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2018-07-22 08:57:36.053
!MESSAGE Using SDK manifest 'ksdk_manifest.xml'.
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2018-07-22 08:57:36.279
!MESSAGE Using manifest XSD 'rsc/manifest_v3.3.xsd' for manifest '/usr/local/mcuxpressoide-10.2.0_759/ide/plugins/com.nxp.mcuxpresso.core.datamodels.resources_10.2.0.201805151128/override/override_manifest.xml'.
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2018-07-22 08:57:36.308
!MESSAGE Using SDK manifest 'override_manifest.xml'.
!ENTRY org.eclipse.cdt.core 1 0 2018-07-22 08:58:22.073
!MESSAGE Indexed 'Eje2' (6 sources, 6 headers) in 1,12 sec: 626 declarations; 443 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0 %)
!ENTRY org.eclipse.jface 4 2 2018-07-22 08:58:54.776
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface".
!STACK 0
java.lang.IllegalArgumentException: Path must include project and resource name: /Eje2
at org.eclipse.core.runtime.Assert.isLegal(Assert.java:63)
at org.eclipse.core.internal.resources.Workspace.newResource(Workspace.java:2074)
at org.eclipse.core.internal.resources.Container.getFile(Container.java:193)
at com.crt.debugcommon.flash.AbstractNXPLaunchConfigHandler.hasExecutable(AbstractNXPLaunchConfigHandler.java:601)
at com.crt.debugcommon.flash.AbstractNXPLaunchConfigHandler.isValid(AbstractNXPLaunchConfigHandler.java:583)
at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationTabGroupViewer.refresh(LaunchConfigurationTabGroupViewer.java:525)
at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationsDialog.updateButtons(LaunchConfigurationsDialog.java:1592)
at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationsDialog.handleLaunchConfigurationSelectionChanged(LaunchConfigurationsDialog.java:1015)
at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationsDialog$4.selectionChanged(LaunchConfigurationsDialog.java:621)
at org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredViewer.java:872)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.ui.internal.JFaceUtil.lambda$0(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:173)
at org.eclipse.jface.viewers.StructuredViewer.firePostSelectionChanged(StructuredViewer.java:869)
at org.eclipse.jface.viewers.StructuredViewer.handlePostSelect(StructuredViewer.java:1238)
at org.eclipse.jface.viewers.StructuredViewer.lambda$0(StructuredViewer.java:1261)
at org.eclipse.swt.events.SelectionListener$1.widgetSelected(SelectionListener.java:81)
at org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(OpenStrategy.java:261)
at org.eclipse.jface.util.OpenStrategy.access$5(OpenStrategy.java:256)
at org.eclipse.jface.util.OpenStrategy$1.lambda$1(OpenStrategy.java:426)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:37)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:182)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4577)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4186)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:818)
at org.eclipse.jface.window.Window.open(Window.java:794)
at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationsDialog.open(LaunchConfigurationsDialog.java:1203)
at org.eclipse.debug.ui.DebugUITools$3.run(DebugUITools.java:629)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
at org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDialogOnGroup(DebugUITools.java:637)
at org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDialogOnGroup(DebugUITools.java:570)
at org.eclipse.debug.ui.actions.OpenLaunchDialogAction.run(OpenLaunchDialogAction.java:82)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:473)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:565)
at org.eclipse.jface.action.ActionContributionItem.lambda$4(ActionContributionItem.java:397)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5348)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1348)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4602)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4183)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1150)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1039)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
at org.eclipse.equinox.launcher.Main.main(Main.java:1472)
!ENTRY org.eclipse.ui 4 4 2018-07-22 08:58:54.998
!MESSAGE An internal error has occurred.
!STACK 0
at org.eclipse.debug.ui.AbstractLaunchConfigurationTab.updateLaunchConfigurationDialog(AbstractLaunchConfigurationTab.java:113)
at org.eclipse.debug.ui.AbstractLaunchConfigurationTab$1.runInUIThread(AbstractLaunchConfigurationTab.java:471)
at org.eclipse.ui.progress.UIJob.lambda$0(UIJob.java:95)
!ENTRY org.eclipse.cdt.core 1 0 2018-07-22 09:01:55.741
!MESSAGE Indexed 'Eje2' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0 %)
!ENTRY org.eclipse.jface 4 2 2018-07-22 09:02:18.606
!STACK 0
at org.eclipse.debug.ui.actions.AbstractLaunchToolbarAction.runInternal(AbstractLaunchToolbarAction.java:92)
at org.eclipse.debug.ui.actions.AbstractLaunchHistoryAction.runWithEvent(AbstractLaunchHistoryAction.java:420)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:237)
at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:219)
at org.eclipse.jface.action.ActionContributionItem.lambda$5(ActionContributionItem.java:436)
!ENTRY org.eclipse.ui 4 4 2018-07-22 09:02:18.779
!STACK 0
!ENTRY org.eclipse.core.jobs 4 2 2018-07-22 09:02:34.570
!MESSAGE An internal error occurred during: "Launching Eje2 Debug".
!STACK 0
Mariano
Hi Mariano,
thanks for sharing the log. It seems to me that there is a problem with the launch configuration and it fails to find the executable file. Could you share a screenshot what launch/debug configuration you try to debug?
Otherwise I think someone from engineering need to have a look, or maybe you even could share/post your project?
Erich
Hi Erich,
Next are the screenshots:
With Eje1 project (is the same result with Eje2 project):
Regard the projects or workspace, of course, here is the zip file:
Finally, I don't know how can I ask to engineering team. Can you?
BR!
Mariano
Hi Mariano,
I hope this helps,
Erich
Hi Erich, thank you so much for your help and thank you very much for giving notice to the engineering team!
With that configuration "shared file" my problem was fixed, so now I can use the IDE smoothly.
Thanks for everything again.
Mariano
