MCUXpresso config tools eFlexPWM clock issue
EnBono
I noticed a problem while trying to configure the PWM on the LPC55S36 using MCUXpresso config tools.
Comparing the PWM initialization from the config tools with the one present in the SDK (driver_examples/pwm), it seems that it's missing the enabling of PWM clock (Let's assume that i want to configure PWM0, submodule 0, the missing instruction is SYSCON->PWM0SUBCTL |= SYSCON_PWM0SUBCTL_CLK0_EN_MASK;)
I tried to search something both in peripherals configuration and clocks configuration but i can't find a way to enable that clock.
The only workaround i found is to add custom software initialization in peripherals configuration and add that instruction manually (Custom_sw_initialization_init function called before PWM0_init).
am i missing something from the config tools?
Labels (2)
xiangjun_rong
For LPC5536 and SDK package,I suppose that you can use the following api function to enable the PWM gated clock.
CLOCK_EnableClock(kCLOCK_Pwm0);
The kCLOCK_Pwm0 macro is defined in the fsl_clock.h.
I copy the macro:
typedef enum _clock_ip_name
kCLOCK_IpInvalid = 0U, /*!< Invalid IP name. */
kCLOCK_Rom = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 1U), /*!< Clock gate name: Rom. */
kCLOCK_Sram1 = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 3U), /*!< Clock gate name: Sram1. */
kCLOCK_Sram2 = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 4U), /*!< Clock gate name: Sram2. */
kCLOCK_Sram3 = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 5U), /*!< Clock gate name: Sram3. */
kCLOCK_Sram4 = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 6U), /*!< Clock gate name: Sram4. */
kCLOCK_Flash = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 7U), /*!< Clock gate name: Flash. */
kCLOCK_Fmc = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 8U), /*!< Clock gate name: Fmc. */
kCLOCK_Flexspi = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 10U), /*!< Clock gate name: Flexspi. */
kCLOCK_InputMux = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 11U), /*!< Clock gate name: InputMux. */
kCLOCK_Iocon = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 13U), /*!< Clock gate name: Iocon. */
kCLOCK_Gpio0 = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 14U), /*!< Clock gate name: Gpio0. */
kCLOCK_Gpio1 = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 15U), /*!< Clock gate name: Gpio1. */
kCLOCK_Gpio2 = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 16U), /*!< Clock gate name: Gpio2. */
kCLOCK_Gpio3 = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 17U), /*!< Clock gate name: Gpio3. */
kCLOCK_Pint = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 18U), /*!< Clock gate name: Pint. */
kCLOCK_Gint = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 19U), /*!< Clock gate name: Gint. */
kCLOCK_Dma0 = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 20U), /*!< Clock gate name: Dma0. */
kCLOCK_Crc0 = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 21U), /*!< Clock gate name: Crc. */
kCLOCK_Wwdt = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 22U), /*!< Clock gate name: Wwdt. */
kCLOCK_Rtc0 = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 23U), /*!< Clock gate name: Rtc0. */
kCLOCK_Mailbox = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 26U), /*!< Clock gate name: Mailbox. */
kCLOCK_Adc0 = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 27U), /*!< Clock gate name: Adc0. */
kCLOCK_Adc1 = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 28U), /*!< Clock gate name: Adc1. */
kCLOCK_Dac0 = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 29U), /*!< Clock gate name: Dac0. */
kCLOCK_Mrt = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 0U), /*!< Clock gate name: Mrt. */
kCLOCK_Ostimer = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 1U), /*!< Clock gate name: Ostimer. */
kCLOCK_Sct = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 2U), /*!< Clock gate name: Sct. */
kCLOCK_Mcan = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 7U), /*!< Clock gate name: Mcan. */
kCLOCK_Utick = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 10U), /*!< Clock gate name: Utick. */
kCLOCK_FlexComm0 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 11U), /*!< Clock gate name: FlexComm0. */
kCLOCK_FlexComm1 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 12U), /*!< Clock gate name: FlexComm1. */
kCLOCK_FlexComm2 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 13U), /*!< Clock gate name: FlexComm2. */
kCLOCK_FlexComm3 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 14U), /*!< Clock gate name: FlexComm3. */
kCLOCK_FlexComm4 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 15U), /*!< Clock gate name: FlexComm4. */
kCLOCK_FlexComm5 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 16U), /*!< Clock gate name: FlexComm5. */
kCLOCK_FlexComm6 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 17U), /*!< Clock gate name: FlexComm6. */
kCLOCK_FlexComm7 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 18U), /*!< Clock gate name: FlexComm7. */
kCLOCK_MinUart0 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 11), /*!< Clock gate name: MinUart0. */
kCLOCK_MinUart1 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 12), /*!< Clock gate name: MinUart1. */
kCLOCK_MinUart2 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 13), /*!< Clock gate name: MinUart2. */
kCLOCK_MinUart3 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 14), /*!< Clock gate name: MinUart3. */
kCLOCK_MinUart4 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 15), /*!< Clock gate name: MinUart4. */
kCLOCK_MinUart5 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 16), /*!< Clock gate name: MinUart5. */
kCLOCK_MinUart6 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 17), /*!< Clock gate name: MinUart6. */
kCLOCK_MinUart7 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 18), /*!< Clock gate name: MinUart7. */
kCLOCK_LSpi0 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 11), /*!< Clock gate name: LSpi0. */
kCLOCK_LSpi1 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 12), /*!< Clock gate name: LSpi1. */
kCLOCK_LSpi2 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 13), /*!< Clock gate name: LSpi2. */
kCLOCK_LSpi3 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 14), /*!< Clock gate name: LSpi3. */
kCLOCK_LSpi4 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 15), /*!< Clock gate name: LSpi4. */
kCLOCK_LSpi5 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 16), /*!< Clock gate name: LSpi5. */
kCLOCK_LSpi6 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 17), /*!< Clock gate name: LSpi6. */
kCLOCK_LSpi7 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 18), /*!< Clock gate name: LSpi7. */
kCLOCK_BI2c0 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 11), /*!< Clock gate name: BI2c0. */
kCLOCK_BI2c1 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 12), /*!< Clock gate name: BI2c1. */
kCLOCK_BI2c2 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 13), /*!< Clock gate name: BI2c2. */
kCLOCK_BI2c3 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 14), /*!< Clock gate name: BI2c3. */
kCLOCK_BI2c4 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 15), /*!< Clock gate name: BI2c4. */
kCLOCK_BI2c5 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 16), /*!< Clock gate name: BI2c5. */
kCLOCK_BI2c6 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 17), /*!< Clock gate name: BI2c6. */
kCLOCK_BI2c7 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 18), /*!< Clock gate name: BI2c7. */
kCLOCK_FlexI2s0 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 11), /*!< Clock gate name: FlexI2s0. */
kCLOCK_FlexI2s1 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 12), /*!< Clock gate name: FlexI2s1. */
kCLOCK_FlexI2s2 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 13), /*!< Clock gate name: FlexI2s2. */
kCLOCK_FlexI2s3 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 14), /*!< Clock gate name: FlexI2s3. */
kCLOCK_FlexI2s4 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 15), /*!< Clock gate name: FlexI2s4. */
kCLOCK_FlexI2s5 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 16), /*!< Clock gate name: FlexI2s5. */
kCLOCK_FlexI2s6 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 17), /*!< Clock gate name: FlexI2s6. */
kCLOCK_FlexI2s7 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 18), /*!< Clock gate name: FlexI2s7. */
kCLOCK_Dmic = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 19U), /*!< Clock gate name: Dmic. */
kCLOCK_Timer2 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 22U), /*!< Clock gate name: Timer2. */
kCLOCK_Usbd0 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 25U), /*!< Clock gate name: Usbd0. */
kCLOCK_Timer0 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 26U), /*!< Clock gate name: Timer0. */
kCLOCK_Timer1 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 27U), /*!< Clock gate name: Timer1. */
kCLOCK_Dma1 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 1U), /*!< Clock gate name: Dma1. */
kCLOCK_Comp = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 2U), /*!< Clock gate name: Comp. */
kCLOCK_Freqme = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 8U), /*!< Clock gate name: Freqme. */
kCLOCK_Cdog = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 11U), /*!< Clock gate name: Cdog. */
kCLOCK_Rng = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 13U), /*!< Clock gate name: Rng. */
kCLOCK_Pmux1 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 14U), /*!< Clock gate name: Pmux1. */
kCLOCK_Sysctl = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 15U), /*!< Clock gate name: Sysctl. */
kCLOCK_Usbhmr0 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 16U), /*!< Clock gate name: Usbhmr0. */
kCLOCK_Usbhsl0 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 17U), /*!< Clock gate name: Usbhsl0. */
kCLOCK_Css = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 18U), /*!< Clock gate name: Css. */
kCLOCK_PowerQuad = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 19U), /*!< Clock gate name: PowerQuad. */
kCLOCK_Timer3 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 21U), /*!< Clock gate name: Timer3. */
kCLOCK_Timer4 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 22U), /*!< Clock gate name: Timer4. */
kCLOCK_Puf = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 23U), /*!< Clock gate name: Puf. */
kCLOCK_Pkc = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 24U), /*!< Clock gate name: Pkc. */
kCLOCK_AnalogCtrl = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 27U), /*!< Clock gate name: AnalogCtrl. */
kCLOCK_Hs_Lspi = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 28U), /*!< Clock gate name: Lspi. */
kCLOCK_Gpio_Sec = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 29U), /*!< Clock gate name: Sec. */
kCLOCK_Gpio_Sec_Int = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 30U), /*!< Clock gate name: Int. */
kCLOCK_I3c0 = CLK_GATE_DEFINE(AHB_CLK_CTRL3, 0U), /*!< Clock gate name: I3c0. */
kCLOCK_Enc0 = CLK_GATE_DEFINE(AHB_CLK_CTRL3, 3U), /*!< Clock gate name: Enc0. */
kCLOCK_Enc1 = CLK_GATE_DEFINE(AHB_CLK_CTRL3, 4U), /*!< Clock gate name: Enc1. */
kCLOCK_Pwm0 = CLK_GATE_DEFINE(AHB_CLK_CTRL3, 5U), /*!< Clock gate name: Pwm0. */
kCLOCK_Pwm1 = CLK_GATE_DEFINE(AHB_CLK_CTRL3, 6U), /*!< Clock gate name: Pwm1. */
kCLOCK_Aoi0 = CLK_GATE_DEFINE(AHB_CLK_CTRL3, 7U), /*!< Clock gate name: Aoi0. */
kCLOCK_Aoi1 = CLK_GATE_DEFINE(AHB_CLK_CTRL3, 8U), /*!< Clock gate name: Aoi1. */
kCLOCK_Ftm0 = CLK_GATE_DEFINE(AHB_CLK_CTRL3, 9U), /*!< Clock gate name: Ftm0. */
kCLOCK_Dac1 = CLK_GATE_DEFINE(AHB_CLK_CTRL3, 10U), /*!< Clock gate name: Dac1. */
kCLOCK_Dac2 = CLK_GATE_DEFINE(AHB_CLK_CTRL3, 11U), /*!< Clock gate name: Dac2. */
kCLOCK_Opamp0 = CLK_GATE_DEFINE(AHB_CLK_CTRL3, 12U), /*!< Clock gate name: Opamp0. */
kCLOCK_Opamp1 = CLK_GATE_DEFINE(AHB_CLK_CTRL3, 13U), /*!< Clock gate name: Opamp1. */
kCLOCK_Opamp2 = CLK_GATE_DEFINE(AHB_CLK_CTRL3, 14U), /*!< Clock gate name: Opamp2. */
kCLOCK_Hscmp0 = CLK_GATE_DEFINE(AHB_CLK_CTRL3, 15U), /*!< Clock gate name: Hscmp0. */
kCLOCK_Hscmp1 = CLK_GATE_DEFINE(AHB_CLK_CTRL3, 16U), /*!< Clock gate name: Hscmp1. */
kCLOCK_Hscmp2 = CLK_GATE_DEFINE(AHB_CLK_CTRL3, 17U), /*!< Clock gate name: Hscmp2. */
kCLOCK_Vref = CLK_GATE_DEFINE(AHB_CLK_CTRL3, 18U) /*!< Clock gate name: Vref. */
} clock_ip_name_t;
Hope it can help you
XiangJun Rong
