MCUXpresso PLU LPC55 schematic error
2,621 次查看
BertrandR
Tool : MCUXpresso V11.6.1_8255
MCU : LPC55S28
I can't find how to display PLU schematic in my project.
When I open the schematic view , I have a java error :
Thanks for your support.
Bertrand
标签 (2)
标记 (1)
2,597 次查看
RaRo
Hello @BertrandR,
Please follow the next steps to access the PLU Configuration Tool:
  1. Open ConfigTools -> Peripherals.
  2. Then, in Components section, go to Register initialization.
  1. A new window will open, please select PLU
  1. Now the Peripherals window should look as below:
Click on the Open Schematic View.
  1. Finally, go ahead and create your schematic.
Best regards, Raul.
2,589 次查看
BertrandR
Thank You Raul.
I have a remaining problem, The system tell me that I need Config Tool V12.1. It should be already included in my MCUXpresso version 11.6.1
May be I have to reinstall it completly?
Bertrand
2,597 次查看
RaRo
Hello @BertrandR,
Best regards, Raul.
