MCU Xpresso IDE
MCU Xpresso IDE
DHARSAN
what is axf and bin format of file in flash tool?
ZhangJennie
Hi DHARSAN,
axf is ARM executable format (AXF) file, which is actually standard ELF/DWARF file. Project *.axf file is automatically generated after a successful build. Take a look at your project folder if you need it.
bin file is binary format file. When we have a axf file generated, right click on the generated axf file in "project explore" window, "Binary files", "Create binary", *.bin file will be created.
We can use either axf or bin file for Flash programing.
Hope this helps,
Jun Zhang
