Links on old posts do not redirect correct
1,788件の閲覧回数
lpcware
Content originally posted in LPCWare by gnxp on Mon Sep 22 07:09:38 MST 2014
Environment -
mozilla 32.0.2 on Windows
While searching through forums, you often come across links to old posts as response. But if you click on them, it just takes you to forum homepage and not the clicked forum post. Is there any solution to this?
4 返答(返信)
1,698件の閲覧回数
lpcware
Content originally posted in LPCWare by Nathalie6 on Tue Dec 30 07:34:57 MST 2014
I have the same problem ... too bad there was no solutions
Nathalie6 @ Lyonmétropole
1,698件の閲覧回数
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Thu Sep 25 00:24:02 MST 2014
Sorry, I don't believe there is.
LPCXpresso Support
1,698件の閲覧回数
lpcware
Content originally posted in LPCWare by gnxp on Wed Sep 24 02:28:27 MST 2014
Ok, thank you for the response. Just curious, is there any other way to search them using the post number?
Thank you
1,698件の閲覧回数
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Tue Sep 23 10:31:49 MST 2014
Sorry. No. This was an unfortunate side affect of the migration of the data from the original LPCXpresso forum (knowledgebase.nxp.com) into the the LPCware forum system that we weren't able to find a solution for. However this only affects older posts - the migration took place well over a year ago now.
LPCXpresso Support
