LPC845-BRK: Error JP1/JP2 in doc
2,237件の閲覧回数
1234567890
Manual and schematic mixed up function of JP1 and JP2.
2 返答(返信)
2,141件の閲覧回数
BlackNight
Yes, the JP1 and JP2 were indeed mixed up in the board document, I had found this while writing up Tutorial: Transforming the NXP LPC845-BRK into a CMSIS-DAP Debug Probe | MCU on Eclipse. I had reported the problem and received an updated document (attached) which should be on the web soon.
I hope this helps,
Erich
2,141件の閲覧回数
ZhangJennie
In order to check this problem efficiently, can you please specify
1. what's the concrete problem you have?
2. what's the expecting result?
Jun Zhang
